Error Codes
2026-09-20
Note
This document lists common error codes and their meanings for each module of FlightHub 2, to help developers quickly locate issues. The document is continuously updated, and timeliness cannot be guaranteed. If it differs from actual runtime messages or has omissions, the messages shown in the product interface take precedence.
Code ▼DescriptionCategory ▼MessageReasonSolution
219004Task expired: the created task time is earlier than the current time. Task execution failed and this message is shown.Task LibraryTask expired. Unable to perform taskTask expiredRe-select the task execution time in FlightHub 2
219014Device does not belong to this projectTask LibraryDock does not belong to project. Unable to perform operation or task. Bind dock to project or enter project that dock belongs to and try againDock does not belong to project, permission isolationCheck whether the dock's project matches
219016Task is suspended; execution failedTask LibraryTask suspended. Unable to perform taskTask suspendedCheck whether the task is suspended
219018Task device did not respond within timeoutTask LibraryNo response from dock for 1 hr when performing taskDevice offline or messaging connection interrupted, unable to report1. Check whether the dock is powered on 2. Check whether the dock network is normal 3. If not resolved, contact after-sales to retrieve logs and file a ticket for analysis
219031Abnormal errorTask LibraryTask failed. Live Flight Controls enabled
219032Failed to get aircraft properties: dock and aircraft not linked or no aircraft in the dockTask LibraryFailed to power on aircraft, or aircraft not connected. Make sure aircraft is inside dock, battery installed, and dock and aircraft linked. Restart dock and try again
219034Resumable-flight task created but not executed for more than three days; task expiredTask LibraryTask for resuming from breakpoint not performed for more than 3 days. Task has automatically expired for enhanced safety
219037Failed to get takeoff/landing zone; cannot execute route task. Usually a server issue and cannot be resolved by the user.Task LibraryTask failed. Unable to obtain takeoff/landing area info. Restart dock and distribute task again. Contact DJI Support if issue persists
219038Route task takeoff queue timeout; task failedTask LibraryTask failed. Task queuing timed out. Check whether takeoff/landing area is available and try again
219101Failed to call device control serviceTask LibraryServer error. Try again laterDevice control service abnormalRetrieve dock logs and contact after-sales for analysis
219102Dock is offline; cannot perform flight task. Check whether the dock is powered off and its network is normal.Task LibraryDevice offline. Unable to perform task. Check whether device is powered off and network connection is normalDevice offline or messaging connection interrupted, unable to report1. Check whether the dock is powered on 2. Check whether the dock network is normal 3. If not resolved, retrieve logs and contact after-sales for analysis
219103Device does not exist (internal:212016)Task LibraryDock does not exist in project. Unable to perform taskDock does not belong to project, permission isolation1. Check whether the dock's project matches
219104Device control service command does not exist (internal:212017)Task LibraryInternal server error. Unable to perform taskService configuration error, command not recognizedContact after-sales to retrieve logs and file a ticket (dock logs)
219105Device control service send command timeout (internal:212018)Task LibraryCloud-dock communication error. Unable to perform taskDock did not reply to task command within 10 secondsContact after-sales to retrieve logs and file a ticket (dock logs)
219106Device control service reported task device timeout (internal:212024)Task LibraryNo response from dock when performing task, timed outDock task progress not reported within timeout
