Safety and FAQ
2026-09-23
Flight Safety
  • Confirm flight parameters: Before dispatching, make sure parameters such as flight altitude, speed, and return-to-home altitude are reasonable.
  • Monitor battery level: Before long-range flight tasks, ensure the aircraft has sufficient battery power.
  • Check airspace: Confirm there are no no-fly zones or obstacles along the flight path.
  • Weather conditions: Do not take off in severe weather (strong wind, heavy rain, dense fog).
Control Safety
  • Virtual joystick control: After obtaining control, operate carefully to avoid abrupt turns or rapid ascent/descent.
  • RTH first: In any uncertain situation, prioritize return-to-home.
  • Exit control: Release control promptly after operation to avoid accidental input.
Network Safety
  • Stable network: Ensure a stable mobile network connection (4G/5G or Wi-Fi recommended).
  • Disconnection handling: If network is interrupted during livestream, the aircraft executes the preset lost-link action (hover/RTH).
FAQ
Q: What if multiple users dispatch the same device at the same time through One-Tap Dispatch?
A: The system prioritizes tasks by alert level. Higher-level tasks are dispatched first. Lower-priority tasks queue until the device is available.
Q: Which third-party apps are supported for map navigation?
A: Mainstream third-party navigation apps are supported, including Amap, Baidu Maps, Tencent Maps, and Google Maps. When opening navigation, you will see a selection list of installed navigation apps on your phone.
Q: What is the livestream latency?
A: It is generally consistent with the cockpit latency in DJI FlightHub 2.
Q: How do virtual joystick directions map to aircraft movement?
A: By default, the virtual joysticks use Mode 2. The left stick controls ascent/descent and yaw rotation, and the right stick controls forward/backward and left/right translation relative to aircraft heading. You can tap "Settings" in the portrait control panel after obtaining control to change joystick mode.
Q: What happens to the aircraft after exiting the app?
A: Regardless of whether control has been obtained, if the app stays in background for more than 5 minutes, the livestream window closes automatically and control is released. After app exit or network interruption, the aircraft executes the device preset lost-link action (typically hover in place or automatic return-to-home).
