On-Premises Version
2026-10-20
2026-10-21 V2.0.1
V2.0.1 introduces the built-in Plugin Framework for DJI FlightHub 2. It is currently available in beta in China, with availability expanding to other regions in future releases.
2026-10-14 V2.0
I. On-Premises Version Feature Optimizations
1. New Device Support
  • DJI FlightHub 2 now supports DJI Dock 4.
Usage limitation: DJI Dock 4 currently supports HTTPS only. Enable the HTTPS option in the admin console. For details, see the Switching HTTP and HTTPS chapter in the On-Premises deployment manual.
2. Cluster Architecture Support
Starting with V2.0, a cluster architecture provides high availability, load balancing, and disaster recovery backups to support larger-scale, more reliable, and more secure flight operations. Visual operations, fewer deployment environment dependencies, and improved deployment success rates also reduce deployment and maintenance costs.
Deploy DJI FlightHub 2 on a single node initially and add nodes as your business needs grow. When the number of nodes is ≥ 3, the cluster provides the following features:
  • High availability: automatic failover when a node fails keeps core services running.
  • Load balancing: tasks are allocated based on node resources to prevent individual machines from being overloaded.
  • Disaster recovery backups: multiple backup replicas reduce data loss and downtime.
Key Additions to the Admin Console
  • Node expansion: add nodes online without interrupting services. Supports progress monitoring, retries after failures, rollback of reversible stages, and process log export.
    • Requirement: the license certificate must allow a maximum device count of at least 20.
  • Cluster maintenance: centrally view cluster health, topology, and alerts in the cluster overview, along with node hardware information and CPU, memory, storage, and network load.
  • Value-added services: deploy and manage services such as 4G and Terra with one click, view deployment progress and health status, and export process logs.
  • License management: designate a node within the cluster or a remote node for centralized license management.
    • Usage limitation: each cluster supports only one license node, and all licenses must be installed on that node.
Key Compatibility Changes
  • License installation: DJI FlightHub 2, 4G, and Terra licenses must be installed on the same license node. If your licenses are installed on separate machines, contact after-sales support to migrate them before upgrading to V2.0.
  • Upgrade restrictions: earlier versions cannot be upgraded to V2.0 using visual tools, legacy command-line tools, or similar methods. Follow the On-Premises deployment manual carefully.
  • Data backups: backup commands and procedures have changed. Follow the On-Premises deployment manual carefully.
  • Routine maintenance: maintenance commands have been replaced, DJI FlightHub 2 service log export has changed, and the port list has been updated. Read the On-Premises deployment manual carefully.
  • Feature adjustments: remote maintenance, login screen customization, and alert rule modification are temporarily unavailable.
3. Livestream Engine Redesign
  • A new in-house livestream media engine redesigns the underlying livestream experience, increasing single-machine concurrent livestream capacity by 2.8 times while further reducing CPU usage.
  • Improved GB-28181 and RTMP protocol compatibility makes integration with common video surveillance platforms such as Hikvision easier.
  • Supports dynamic scaling to eliminate software throughput bottlenecks. Concurrent capacity depends on network interface bandwidth.
4. Maintenance Experience Optimizations
  • Smaller installation package: the package size has been reduced to within 50 GB.
  • Improved license tolerance: the existing license remains valid when replacing the hard drive or network interface, or reinstalling the operating system on the same machine. No license reissuance is required, reducing service interruptions caused by routine maintenance.
  • Improved expiration notifications: upgrade license expiration and trial license expiration are distinguished, with more accurate descriptions of their impact. Device limit alerts are less frequent to reduce repeated reminders.
5. MQTT Bridge API Authentication Support
Local MQTT registration, modification, and other operations require x-user-token for API authentication to prevent unauthorized users from changing MQTT configurations. You can enable authentication on the "DJI FlightHub 2 - Organization Settings - FlightHub Sync - MQTT" page.
6. O4 Ground Station Device Count Optimization
When the O4 Ground Station is in "Gateway Mode - Roaming Base Station Mode", it no longer counts toward the licensed number of online devices.
Special note: The release of the all-in-one machine has been postponed until next week.
II. Public Cloud Feature Alignment (aligned to 2026-09-01)
1. Smart Search Supports Count Statistics and Conditional Alerts
  • "Cockpit - Multimodal Smart Search", "Mission Library - Multimodal Configuration", and "Analyzer - Smart Search": search results now display target counts. You can set count alert thresholds in prompts so that alerts are triggered only when the conditions are met. Combined searches for multiple targets are also supported.
  • "Flight Records" and "Analyzer": Smart Search alert results support manually editing AI search targets and manually adding or removing targets.
2. Automated Workflow Optimizations
  • Periodic workflows now include VLM Smart Search and Change Detection Pro sub-modules, allowing AI analysis tasks to be configured directly within the workflow.
  • Triggered workflows now include a Search in Place action. Combined with the intelligent recognition action, it can search for specified targets after the aircraft reaches the target location.
  • The workflow list now includes Notification / AI tags, and execution logs show trigger methods and notification results.
3. Change Detection Pro Support
  • After deploying the VLM vision-language model, you can use Change Detection Pro with the same capabilities as the public cloud version.
4. Analyzer Supports Smart Search
  • A large model automatically identifies target information, which you can manually convert into annotations mapped onto the model and then use to generate operation reports.
5. More Features
  • The waypoint route editor now supports setting above-ground altitude alert thresholds.
  • The Analyzer model timeline now supports filtering by model type.
  • Third-party developers and users who need to integrate DJI FlightHub 2 into an existing system can refer to FlightHub Integration Skill to accelerate integration or explore potential solutions.
  • Multimodal recognition in the Cockpit and Smart Search in the Analyzer now support reverse geolocation calculation for up to 10 targets. The calculated coordinates are for reference only.
  • The map now supports creating spatial lines and polygons. Once drawn, they can be viewed on the map and in the Cockpit AR projection.
  • Livestream sharing links now remember the page layout.
  • OpenAPI V2.0 sample source code released: after deploying and successfully running the sample source code, you can experience the feature interface developed with OpenAPI V2.0. This helps you quickly understand OpenAPI integration and usage and accelerates secondary development and integration. For details, see the On-Premises OpenAPI V2.0 Manual.
Special notes:
  • Copilot features are not yet supported.
  • Stream input from DJI consumer drones and handheld devices is not yet supported.
2026-08-17 V1.7.1
Note: This version fixes known issues from V1.7.0.
1、Fixed Occasional Offline Issue When Devices Connect to Cloud
  • Fixed a memory issue in the V1.7.0 authorization service to prevent all devices from occasionally going offline after connecting to the cloud.
2、Removed MQTT Bridge LAN Restriction
  • Removed the LAN IP restriction on MQTT Bridge in V1.7.0 to prevent existing configurations from becoming unavailable.
3、Fixed Cockpit Component Return-to-Home Issue
4、Fixed Missing Screenshots in 3D Gaussian Splatting Reconstruction Reports
5、Removed es-one-api Container to Reduce Redundant Services
2026-08-06 v1.7
I. Functionality Alignment (aligned to 2026-06-30)
1、Automation - Triggered Workflow Optimizations
  • Triggered workflows now support selecting the DJI Dock 2 as the operating device.
  • Added a multimodal recognition action, which can start multimodal recognition during flight or after reaching a specified location.
  • Supports customizing the dispatch delay time, allowing dispatch as soon as 0 seconds after an alert is triggered.
  • Supports exporting alert points from the dispatch log to the project annotation folder with one click, making it easier to analyze alert hotspot areas.
  • The EventApi adds information synchronization for dispatch workflows, enabling alert process and result information to be pushed to third-party systems.
  • Added a "False Alarm" tag, allowing the current alert task to be tagged as a false alarm in the Cockpit and viewed in the dispatch log.
2、Flight Records Support Viewing Video Files
  • Added a video file timeline track: video files captured by the payload can be reviewed on the flight record timeline.
  • Optimized the flight record toolbar: supports viewing all media files generated by this flight mission in the media records.
II. On-Premises Version Feature Optimizations
1、Cockpit and Flight Plan Library Support O4 Ground Station
The Cockpit and Flight Plan Library now support adding the "O4 Ground Station" as a signal enhancement device. Regular missions can select nearby available stations to connect, extending the operating range of a single sortie.
  • Known Issue: After the Cockpit or flight mission is completed, the dock and the ground station may fail to decouple properly, causing the Cockpit icon to appear grayed out and the device to be unable to take off again.
  • Temporary Solution: Remotely restart the corresponding device via DJI FlightHub 2 to restore it. This issue will be fixed in a future firmware version.
2、V1.7 Incremental Upgrade Package Released
This version provides an incremental installation package that supports quickly upgrading an existing environment from V1.6 to V1.7 via incremental upgrade. Compared with a full upgrade, an incremental upgrade only needs to update the necessary services that have changed, significantly reducing upgrade time and downtime.
3、OpenAPI V2.0 Sample Source Code Released
After deploying and successfully running the sample source code, you can experience the feature interface developed based on OpenAPI V2.0. This helps you quickly understand the integration and usage of OpenAPI and accelerates secondary development and integration. For details, see the manual: "On-Premises OpenAPI V2.0 Manual".
4、Version Number Naming Optimization
To help customers accurately identify the current on-premises version, this version unifies the version number display rules. After upgrading, the DJI FlightHub 2 organization management page and admin console will display a standard version number, for example: V1.7.0.
5、Admin Console Configuration Efficiency Optimization
When modifying configurations, the time required for the service to take effect and recover is shortened.
6、Deployment Capability Optimization
Fixes and optimizes a series of common deployment issues, improving the success rate of DJI FlightHub 2 deployment and upgrades.
7、Visual Upgrade Optimization
Fixes a series of upgrade issues and optimizes the technical architecture of the upgrade capability, improving stability and scalability.
8、Developer Console "History" Optimization
You can now obtain the installation package information for the On-Premises version and the all-in-one machine more clearly through "History".
9、Deployment Manual Changed to Online Documentation
Supports online viewing, searching, and downloading as PDF.
10、Removal of Installation Packages for DJI FlightHub 2 V1.5 and Earlier
For product security and stability reasons, we will remove the installation packages for DJI FlightHub 2 V1.5 and earlier versions. If you still need them, please contact your local industry application partner or DJI technical support for assistance.
2026-06-16 v1.6
1、O4 Ground Station Support Added
  • DJI FlightHub 2 now supports the "O4 Ground Station", enabling device management of cloud-connected O4 Ground Stations on DJI FlightHub 2.
  • The Cockpit and Flight Plan Library now support "O4 Ground Station" as a signal enhancement device. Regular missions can select nearby available stations to connect, extending the operating range of a single sortie.
  • For network cameras connected through the "O4 Ground Station" via the ONVIF and GB/T 28181 standard protocols, you can view the video stream and remotely control them from DJI FlightHub 2.
  • For RID and ADS-B airspace broadcast receivers connected through the "O4 Ground Station", detected aircraft can be viewed on DJI FlightHub 2. You can also handle abnormal situations with one-click dispatch.
2、Defect Annotation Supported in Analyzer
  • The Analyzer now supports defect annotation. Annotations on media files are precisely mapped to spatial positions on the 3D model in the Analyzer.
  • Click any location on the 3D model in the Analyzer to automatically receive recommendations of related photos that may have captured that point.
  • The spatial mapping between 2D media and 3D models has been comprehensively enhanced!
3、AGL Altitude Recording and Alerts
  • Enable AGL (Above Ground Level) altitude alerts in the Cockpit. An alert is triggered when the configured AGL value is exceeded.
  • Flight records now support calculating and displaying changes in altitude above ground during the flight. Note: This altitude is calculated based on the DJI FlightHub 2 global elevation model and may contain errors.
4、Live Share 2.0 Supports Sharing Multiple Devices at Once
  • Live sharing has been fully upgraded to support adding multiple device live streams to a single share link.
5、Automated Workflow Adds Trigger Configuration and Notification Module
  • Automated workflow now supports trigger and notification configuration, allowing more flexible workflow triggering and outbound notifications of workflow status.
6、Copilot-related features and livestreaming from DJI consumer drones and handheld devices are not yet supported *
1、Security Issue Fixes
  • Fixes common security issues found in previous versions. To safeguard system security and stability, it is strongly recommended to upgrade to the current version.
2、OpenAPI V2.0 On-Premises Release
  • Building on the capabilities opened in V1.0, this version takes closed-loop secondary-development scenarios as its core goal and systematically completes APIs for key modules such as device management, flight task management, and data management (media, model, and map), bringing the total number of interfaces to more than 300 (V1.0 had 67).
  • It also restructures the interface system by separating Public Cloud and On-Premises interface documentation, making categorization clearer for faster developer onboarding and integration, and enabling more agile iteration of OpenAPI in the future.
3、Visual Deployment Tool Optimizations
  • Anomaly check now includes "subnet conflict" detection, helping to identify network configuration issues in advance.
  • Supports launching the tool without an installed license.
  • Optimizes the deployment process and exception handling, fixes known issues, and improves overall deployment success rate.
4、Livestream Performance and Stability Improvements
  • Supports multi-core configuration. When CPU resources are sufficient, livestream concurrency can be improved by up to 3× compared to before.
  • Fixes a series of issues, such as livestream failures, forwarding stream failures, livestream black screens, and abnormal latency data, improving livestream service stability.
5、Optimizations to Some Error Messages and Interactions in the Admin Console
2026-04-29 v1.5
I. Functionality Alignment (Aligned to 2026-04-15)
1、High-Definition Panorama
  • DJI Dock 3 and Matrice 4 Enterprise now support 500MP high-definition panoramas for efficient one-click environment data collection.
  • 3× zoom can be set in the virtual cockpit and waypoint route settings to capture sphere panoramas. Automatic stitching is performed after capture. High-definition results can be viewed in the media file library, and support importing into the analyzer to use timeline and related features.
2、Resource Library Upgrade
  • The original media file library, model library, and design files have been merged into the "Resource Library" for unified, more convenient management.
  • A recycle bin has been added. Deleted files are moved to the recycle bin first. Periodic auto-emptying can be configured to free up storage space.
3、Multimodal Recognition for Flight Routes
  • The task plan library now supports enabling multimodal recognition, allowing specified objects to be identified during flight route execution. Users are notified through designated methods when recognition is triggered.
4、Surface Area Measurement in Analyzer
  • Users can quickly measure the surface area of models, facilitating coverage area calculation and cost estimation, significantly improving efficiency in engineering operations.
  • Applicable to scenarios such as earthwork covering, lawn greening, and irregularly curved architectural surfaces.
5、FlightHub Sync
  • FlightHub 2 FlightHub Sync Beta has completed testing and validation. It will be gradually phased out and replaced by the new FlightHub Sync.
  • File Sync – Now supports cross-configuration of file type, project, and bucket. Multiple buckets can be configured simultaneously.
  • Telemetry Data Sync – A new telemetry data sync feature enables real-time syncing of drone attitude data to third-party platforms.
  • Livestream Forwarding – Now supports the RTSP protocol.
  • Added support for Event API, allowing configuration of different event rules to push specific FlightHub events to external systems.
  • File sync now supports automatically deleting source files within FlightHub after sync is complete.
  • Third-Party Airspace Data Management – Supports configuring airspace information from third-party providers and displaying it within FlightHub.
6、FlightHub Mapping API
  • OpenAPI now includes the FlightHub Mapping API, enabling third-party systems to quickly integrate cloud-based mapping capabilities.
7、Gaussian Splatting
  • On-device reconstruction now supports Gaussian Splatting format, delivering more realistic and detailed results in scenes with fine structures and glass curtain walls.
8、Model Sharing
  • The model sharing page supports viewing via mobile phone or tablet scan without requiring login.
9、Sync Annotations to Analyzer
  • The analyzer map settings now support syncing project annotations, with the option to select annotations and convert them to measurements with one click.
10、AirSense ICAO Filtering
  • The "Map Operation Area" on the team page has been upgraded to "Airspace Safety", with new AirSense alert management capabilities, including support for filtering by ICAO number.
11、AI Change Detection
  • Media Change Detection: The media file library now supports intelligent detection and marking of change areas between two media folders generated by the same waypoint route task.
  • Model Change Detection: The model library now supports intelligent detection and marking of change areas between two 2D models with overlapping areas.
12、GCP-Based Reconstruction
  • Cloud reconstruction now supports setting ground control points (GCPs). Standard targets support automatic point marking and automatic reconstruction.
13、Real-Time Megaphone Support
  • Supports initiating voice announcements and TTS announcements directly from the cloud.
1、Visual Deployment
  • Supports completing the deployment of FlightHub, Terra, and 4G services in private environments through a visual interface, replacing traditional command-line and manual configuration methods.
  • Helps customers shorten deployment cycles, lower implementation barriers, and improve deployment success rates. Applicable for initial deployment, first-time implementation, or operations where reduced deployment complexity is desired.
2、Incremental Upgrade
  • Starting from this version, incremental upgrades are supported. Compared to the previous full upgrade approach, only the necessary services that have changed need to be upgraded between adjacent versions, significantly reducing upgrade time and downtime.
  • Note: This capability will take effect after the next version is released. Customers must first upgrade to this version, and can then use incremental upgrades when upgrading from this version to the next adjacent version.
3、Permanent Data Deletion
  • Starting from this version, files deleted from the media file library, model library, and design files will be permanently deleted, and the corresponding storage space will be released simultaneously.
4、AIO Admin Console – New Visual Configuration Options
  • Operations that previously required code, scripts, or manual configuration file editing can now be performed through the AIO Admin Console, reducing O&M learning costs and implementation overhead.
  • Starting from this version, the AIO Admin Console will be deployed together with FlightHub in on-premises environments by default.
5、AIO Admin Console – Experience Optimizations
  • Added display of the FlightHub version number.
  • Map management now supports configuring layer information.
  • Supports one-click HTTPS certificate retrieval.
  • Remote O&M interaction optimized.
  • Log export now supports selecting a time range.
2025-12-23 v1.4
1、Automated Assignment Workflow
  • In automated workflow page, you can create automated assignment workflow, then trigger workflow manually on map or through external system. After aircraft arrives at specified coordinates, preset action will be performed automatically.
2、AI Flight Route Optimization
  • Added support to select 3× or 7× zoom lens for flight route planning in patrol route.
  • Added support for DJI official and third-party infrared object detection algorithms.
  • Added support for speaker and spotlight actions in alert actions.
3、Real-Time Alert Settings in Virtual Cockpit
  • During real-time flight, onboard official and third-party algorithms support setting alert thresholds. After alert is triggered, relevant alerts will be collected into alert list.
4、Historical Elevation
  • Added support for creating point and historical elevation measurements to analyzer. You can draw points on map to obtain the point's geographic location and surface height of historical models.
5、Sharing in Analyzer
  • In analyzer sharing page, you can use mobile device to scan code to view model or media file timeline, measurement results, and analysis reports instantly without login.
6、Zenmuse L3 Payload
  • Added support for planning flight routes for Matrice 400 enterprise aircraft with the Zenmuse L3.
  • Added support for displaying a preliminary report of the L3's point cloud results in area route, which can assess the expected data quality in advance.
  • Added support for viewing L3 point cloud files uploaded from the Pilot 2 app.
7、Flight Data Reporting by Airspace Management Service Providers
  • Enable this feature in Organization Settings > Organization Data Management > Airspace Management Service Provider Flight Data Reporting. After entering the address and token provided by the third-party service provider, flight data will be pushed to them in real time.
8、Model Altitude Calibration
  • Added support for setting altitude calibration points in analyzer. The model surface elevation at the selected location will be calibrated to a designated value for all models in analyzer. This calibrated elevation will be applied to all measurements and calculations.
9、Additional Feature Support
  • Added support for object segmentation algorithm to onboard algorithm.
  • Added support for completing remaining nodes after disabling automated workflow.
  • Added support for using imperial units set by organization in analyzer.
  • Added support for setting expansion or contraction coefficient for volume measurement in analyzer.
  • 「DJI Dock 3」Added support for custom network RTK calibration in vehicle-mounted deployment mode.
  • 「DJI Dock 3」 Added support for clearing all aircraft unlocking licenses with one click.
  • Added support for Japanese, Korean, German, and French.
  • Added support for filtering the annotation list to display annotations as needed.
  • Added support for performing dynamic calculations that follow the model surface for gradient calculation and triangulation tools.
1、Maintenance Optimization for On-Premises Version
  • Added adaptive network capability. When dock, manually operated aircraft, and FlightHub are not on the same subnet, the service layer will perform adaptive forwarding. Enable this by setting MULTIPLE_IP_ENABLE to True in ENV.
  • Added visual console for operations and maintenance management of the on-premises version. Access at: {server IP}:30888.
  • Added support for more than 20 bypass streaming forwarding tasks per server. The number of forwarding channels can now be configured freely according to the server specifications.
2025-10-14 v1.3
1、All-New Virtual Cockpit Interface
  • Redesigned Interface: A complete visual and interactive optimization for a more intuitive experience.
  • Flexible Layouts: Customize the interface with new layout options to fit your needs.
  • Updated Icons: A brand-new icon set provides a cleaner, more refined look for improved clarity.
  • Streamlined Interactions: The user experience has been optimized to make operations faster, smoother, and more intuitive.
2、Multi-Aircraft Control in Virtual Cockpit
  • Manage a group of aircraft for collaborative tasks using the new multi-aircraft control panel.
  • Instantly switch control between different aircraft, enabling a single operator to manage multiple drones.
3、AR Projection for Spatial Lines and Areas
  • AR projection now supports virtual lines and areas for enhanced situational awareness.
  • View spatial lines and areas drawn in DJI Pilot 2 directly in the live view.
4、Dashboard
  • Adds support for dashboard, a new centralized hub for viewing key operational data at a glance.
  • Designed for administrators, it provides the high-level insights needed for effective management.
  • Track core metrics including assets, device status, task schedules, and data outputs to support informed decision-making.
5、Smart Media Search
  • Find what you're looking for faster. Smart Search automatically detects and tags objects in your photos and videos.
  • Export search results as a detailed report for sharing, documentation, and further analysis.
6、Organization Data Management
  • Administrators can now manage data across the entire organization. Easily view and copy annotations, flight routes, models, and GEO Zones between projects.
7、Batch Editing Waypoint Routes
  • Save time by editing multiple waypoints at once. You can now batch-modify waypoint parameters and actions in the Flight Route Editor.
8、Centralized Message Center
  • All notifications are now aggregated into the new Message Center. View historical system messages and customize which alerts you receive in your personal settings.
9、supports Mavic 3T Advanced enterprise aircraft
  • Supports the Mavic 3T Advanced enterprise aircraft, its gimbal camera, and connected PSDK accessories.
  • Supports point, line, and area annotations for Mavic 3T Advanced enterprise aircraft.
10、Manifold 3 Cloud Integration
  • Adds support for remote management and use of Manifold 3 applications via the cloud.
  • Device Management: Adds support for device display and application management for Manifold 3.
  • Virtual Cockpit: Enables launching loaded applications and viewing their effects in real time.
11、Integration of Third-Party Intelligent Algorithms on Aircraft
  • Virtual cockpit adds support for third-party infrared AI recognition algorithms.
  • Users can now view real-time AI recognition results from infrared cameras.
  • For waypoint and patrol routes, you can now choose third-party intelligent algorithms on the aircraft to perform recognition tasks.
12、AI Task Report Export
  • Flight records now support exporting reports for AI-generated warning events.
13、Multimodal Object Detection
  • Virtual cockpit now supports multimodal object detection.
  • Users can define the objects that trigger warnings by entering text, uploading images, or selecting objects in real time.
  • Snapshots will be automatically archived to a dedicated folder in the media file library, with support for tag-based filtering.
  • You can configure warning notification types and set record intervals.
14、AI Warning Record List
  • The AI warning record list in the virtual cockpit and flight records has been upgraded.
  • Supports archiving and displaying records generated by multimodal object detection and cloud-based intelligent algorithms.
15、AR Street Projection
  • The virtual cockpit now features AR street projection.
  • Supports adjusting opacity and height offset, as well as displaying landmarks.
16、Measurement and Calculation
  • Measurement and calculation tools can be created in the analyzer, enabling line and volume measurements based on models and design files.
  • Line Measurement: Supports triangulation and gradient measurements and allows extraction of cross-sections.
  • Volume Measurement: Supports current model volume calculation, two-phase and multi-phase model volume change calculations.
17、Timeline
  • Supports viewing model timeline, allowing quick and dynamic switching to display the model evolution process and intuitively track project progress.
  • Supports viewing media timeline, enabling association and viewing media files by time and spatial dimensions for visual traceability and process management.
18、Analysis Report
  • Supports generating measurement analysis reports, with configurable report covers, measurement areas, and other structured content.
  • Supports report templates, scheduled automatic report generation, and email delivery, facilitating progress tracking, data archiving, and reporting.
19、Automated Workflow
  • Full Process Integration: Integrates flight, mapping, measurement, calculation, and analysis tasks for end-to-end automation from data collection to intelligent analysis.
  • Flexible Task Management: You can freely choose from existing tasks or create new ones, with support for editing and linking to meet different scenario requirements.
  • Efficient Preview and Performance: Preview task results with one click, quickly save and enable automation to improve operational efficiency.
20、Design File Support
  • Supports PDF and DXF formats. Design files can be accurately positioned on the map via coordinate system conversion or matching point calibration.
  • Supports parsing 3DFACE (DXF) to obtain design heights for cross-section and volume calculations.
21、Engineering Coordinate System
  • Project settings now support engineering coordinate system configuration.
  • Supports EPSG universal and custom projected coordinate systems.
  • Supports four or seven parameter calculation and application.
22、Additional Feature Support
  • Supports customizable collision-risk thresholds for manned aircraft; this setting applies only to airport-based aircraft.
  • Supports customization of return-to-home reserve battery levels for airport aircraft. Under high-wind conditions, it is recommended to increase the reserve level appropriately to ensure flight safety.
  • The virtual cockpit supports configuration of infrared image formats.
  • Adds Spanish language support for the user interface.
1. Deployment optimizations for the On-Premises Version
  • Added a deployment guide for AI large models; see the latest On-Premises Version Deployment Manual for details.
  • Added a deployment guide for AR street projection maps; see the latest On-Premises Version Deployment Manual for details.
2. New capabilities in the On-Premises Version
  • Rapid modeling capability: Supports enabling rapid modeling when mapping missions are dispatched. By receiving real-time aerial thumbnail uploads, the system can quickly generate models for emergency scenarios.
  • Notification capability: In the on-premises version, in-app (site) messages can be delivered via email.
  • Spatial display capability: The Organization Management interface can display the current spatial utilization/occupancy of resources.
2025-06-10 v1.2
Release list
DJI FlightHub 2 on-premises version v1.2 is fully aligned in functionality with the DJI FlightHub 2 public version.
1. FlightHub Sync
  • FlightHub Sync Beta has been upgraded to FlightHub Sync. Users can now synchronize specified project media files, flight routes, flight records, and other information to external storage buckets.
2. AI Capabilities Support
  • A new patrol route feature allows users to specify areas for inspection. The system can automatically use intelligent recognition algorithms to identify people, vehicles, and boats within the patrol area and send alert notifications.
  • The virtual cockpit now supports real-time AI recognition of people, vehicles, and boats, and can automatically send alerts based on infrared video streams.
  • The media file library in FlightHub now supports displaying, viewing, and sharing AI-generated videos on the aircraft, showcasing AI recognition results.
3. Live Flight Controls Support
  • Adds support for live flight controls of Matrice 4D series aircraft when connected via remote controller.
  • Users can now issue return-to-home commands to all aircraft within a project with a single click.
4. Management of Algorithms on Aircraft
  • Users can now load third-party algorithms distributed from the DJI Developer website onto aircraft connected to the dock via the Algorithms page.
5. Support for More Features
  • Flight records now support compatibility with DJI Dock 2.
  • When distributing tasks, the system checks the flight route's historical obstacle sensing records and prompts if any exist. If obstacle sensing is triggered during recurring or continuous tasks, subsequent tasks are automatically suspended and must be manually resumed to ensure safety.
  • Adds support for automatic association of abnormal feedback with dock or aircraft logs. After selecting the time, data is automatically matched and the error code field is filled in to improve problem analysis efficiency.
  • Supports remote switching between FlightHub public and on-premises environments for the dock.
  • Supports real-time 2D mapping (requires deployment of mapping service).
On-premises Version Feature Optimization
1. Deployment Optimization
  • Optimized the upgrade process for the on-premises version incremental package, visualizing upgrade checks and installation steps.
  • Upgraded on-premises version operation and maintenance features, supporting server health checks and built-in NTP service.
Issue Fixes
  • Known issues fixed to enhance system stability.
Firmware Version
For supported firmware versions, visit the deployment manual on the DJI Developer website for details, or directly download the latest firmware list to check.
2025-02-27 v1.1
Expansion of Support Capabilities for Aircraft and Docks
New Model Support
  • Matrice 300 RTK and Matrice 350 RTK Enterprise Aircraft: Supports viewing camera view and payload livestream on FlightHub 2.
  • Mavic 3 Enterprise Aircraft: Supports live flight controls of the gimbal camera.
  • Matrice 4 Enterprise Aircraft: Supports live flight controls of the aircraft and gimbal camera and AI recognition of people, vehicles, and boats.
  • DJI Dock 3: Supports AI recognition of people, vehicles, and boats, Smart Track, AI flight route features, vehicle-mounted deployment mode, and multi-drone takeoff/landing capabilities.
New Accessory Support
  • D-RTK 3 Relay Station
  • DJI AS1 Speaker
  • DJI AL1 SpotLight
New Payload Support
  • Zenmuse H30, Zenmuse H30T
  • Zenmuse H20, Zenmuse H20T, Zenmuse H20N
Flight Route Functionality Upgrade
Flight Route Planning
  • Standard geometric route
  • Slope route
  • Smart 3D Capture Route: Supports generating refined routes for mapping (supported by Matrice 4).
  • Ortho Collection for Area Route: Supports enabling Smart Oblique in the area route settings to improve efficiency (supported by Matrice 4).
  • Waypoint Route: New panoramic photo action added; supports swapping start and end points of waypoint routes, with options to switch some continuous actions. When adding video actions, it supports synchronously recording the pose information of the virtual aircraft and camera, automatically adding aircraft yaw angle, gimbal yaw angle, gimbal tilt angle, and camera zoom actions.
Route Management
  • Route Folder: Supports creating multi-level folders to manage route files.
  • Batch Download: Supports batch downloading of flight route library routes.
Flight Route Task
  • Transfer PPK File to FlightHub 2: Supports transferring base station PPK files for flight route tasks to FlightHub 2 and storing the files in the corresponding flight route task folder in the media file library.
Comprehensive Support for AI Features
AI Recognition and Smart Track
  • The virtual cockpit supports real-time AI recognition and automatic alerts when people, vehicles, or boats are detected, and allows instant viewing of alert record details triggered during flight route tasks (supported by Matrice 4 and DJI Dock 3).
  • Third-party algorithm models developed on the DJI Intelligent Computing platform can be imported to and applied in Pilot 2, expanding AI recognition scenarios.
  • The media file library supports the display, counting, and editing of AI recognition results. Currently only wide-angle and zoom photos are supported.
AI Flight Route (Supported by DJI Dock 3)
  • Waypoint routes support intelligent recognition actions, capable of recognizing people, vehicles, boats, or subjects with abnormal high and low-temperature during the flight, and performing actions such as taking photos, recording videos, and waiting for the operator to take over after alerts.
  • The task plan library now supports AI route warning notification, allowing the configuration of alert receiving methods and frequency after subject recognition.
Smart Track
  • The virtual cockpit supports Smart Track, allowing continuous tracking of AI-recognized subjects (supported by DJI Dock 3).
Dock Function Optimization
Flight Operation Capability Enhancement
  • DJI Dock supports canceling tasks when RTK convergence times out.
  • DJI Dock 2 supports emergency landing function.
  • DJI Dock 3
    • Adds support for scheduling devices to take off or land within a project in areas where docks are densely deployed.
    • Adds support for performing the entry/exit routes after takeoff to ensure safe departure before performing flight tasks.
    • Adds a new type of no-landing zone in custom flight areas, preventing aircraft from automatically landing within these zones.
    • Adds support for quick calibration of device location and pre-flight safety checks in vehicle-mounted deployment mode.
    • The Mouselook feature in the virtual cockpit has been upgraded, making First-Person-View (FPV) operation smoother.
Improved Payload Task Capabilities
  • DJI Dock 2 supports manual mode, allowing for shutter, ISO, aperture settings, timed shot, storage settings, video resolution settings, Link Zoom, and more.
  • DJI Matrice 3D adds distortion correction switch function and mechanical shutter function.
Other Supported Features
  • AR Projection: DJI Dock 2 supports AR projection of PinPoints. Users can view PinPoints in the livestream view now.
  • Vision Assist: DJI Dock 2 supports Vision Assist.
  • Discreet Mode: New discreet mode supported by DJI Dock 2 and DJI Dock 3.
  • Remaining Task Time: DJI Dock 2 virtual cockpit now displays the remaining task time.
  • Embedded SRT in Video: Support for embedding and downloading SRT files in videos.
  • Assisted Pinpointing: Adds support to add PinPoints based on the camera orientation for DJI Dock 2 (Terrain data required).
Software Feature Upgrade
New Multi-Channel Livestream
  • Adds support for simultaneous livestreams for multiple devices within a project. Supported devices include the security cameras of the docks and the gimbal cameras of the aircraft. Adds support for other functions such as positioning devices on the map. Task Management Capability Upgrade
  • Supports for subscribing to notifications of dock cover not being closed for an extended period.
  • Adds support for submitting issue reports in the Task Plan library and warning message panel, and viewing feedback analysis results.
Improved Map Function
  • Adds support to create separate folders for annotations.
  • Adds support to add circular annotations.
  • Global search for elements on map: Users can search geographic locations, map annotations, device information, and models or photos that are overlaid on the map.
  • Optimized the user experience when centering elements on the map.
  • Adds support for syncing observed views from Pilot 2 to FlightHub 2 (supported by Matrice 4).
  • Adds support for syncing spatial annotations from Pilot 2 to FlightHub 2 (supported by Matrice 4).
Media Feature Upgrade
  • Adds support to import photos, panoramas, livestream screenshots, videos, and PPK files to FlightHub 2.
  • Adds photo markup shortcut operation tips, and supports modifying markup colors.
  • Adds support to filter photos with unnamed markups.
Model Reconstruction Upgrade
  • Rough models can now be generated during model mapping and used for creating Smart 3D Capture routes.
  • Model reconstruction supports selecting resolution.
FlightHub Sync Upgrade
  • Supports obtaining PPK/SRT files through FlightHub Sync.
  • Supports distributing flight route tasks through FlightHub Sync.
OpenAPI
  • Authentication and Authorization
  • System Services
  • Organization Projects
  • Device Management
  • Livestream Management
  • Flight Route Management
  • Task Management
  • Model Management
  • Annotation Management
Frontend Components
  • Supports flight route creation components, flight route editor components, virtual cockpit components, and project/map components. It also supports custom theme colors and custom styles for components.
MQTT Bridge
  • Provides MQTT bridging and forwarding functionality, supporting the forwarding of dock's MQTT information to third-party systems via FlightHub 2.
Issue Fixes
Firmware Version
ProductFirmware Version
Matrice 350 RTK10.01.08.05
Matrice 300 RTK60.01.08.06
Matrice 30/30T10.01.05.04
DJI RC Plus05.02.13.02
Mavic 3 Enterprise Series10.01.05.03
DJI RC Pro Enterprise Version02.01.05.10
Matrice 4 Series12.00.01.07
DJI RC Plus 201.61.03.03
DJI Dock 399.99.92.50
DJI Dock 210.01.32.05
DJI Dock10.01.02.05
DJI Pilot 299.0.0.1
2024-09-24 v1.0
Release list
After successfully deploying the FlightHub 2 on-premises version, most features and the overall user experience are consistent with those of the public version. The main new and optimized features are as follows:
Basic Functions
  • Supports rapid deployment with Docker. Refer to the DJI FlightHub 2 On-premises Version Deployment Manual for details.
  • By default, the system is accessed using only the IP address after deployment, and there is no need to configure DNS. DNS can also be enabled later if required.
  • Supports importing and configuring offline map data, including importing and displaying road network data.
  • Supports displaying GEO Zones in the offline version.
  • Supports binding docks using DJI Pilot 2, with an option to select "FlightHub 2 On-Premises Version" during binding.
  • Supports offline firmware upgrades and management.
  • Supports quick access to the on-premises version manual by pressing the question mark key on the keyboard from any interface.
  • Supports either a local account system or an OAuth2 account system.
  • Supports basic device and cloud service log retrieval.
  • Supports license expiration reminders.
Features
  • Supports deployment of 2D/3D mapping services.
  • Supports customization of the login page, allowing modification of the logo, background, and other information.
  • FlightHub Sync Beta supports GB28181 streaming format.
  • The FlightHub Sync Beta module supports the distribution of flight route tasks, allowing third-party cloud platform to directly call the interface and distribute Immediate tasks.
  • After successfully deploying the FlightHub 2 on-premises version, it will include the FlightHub 2 on-premises version operations and maintenance platform by default, allowing for a more intuitive view of the operation status of FlightHub on-premises services. You can also monitor the system's running status in real time by adding a Webhook callback to monitor messages.
Firmware Version
Matrice 3D/3TD10.01.1607
DJI RC Pro Enterprise Version02.01.0507
DJI Dock 210.01.1607
Matrice 30/30T10.01.0014
DJI RC Plus05.02.1106
DJI Dock10.01.0205
DJI Pilot 210.1.0.30
Known Issues List
Affected ProductsIssue DescriptionWorkaround
All modelsWhen clicking the device status window button to watch the livestream, the virtual cockpit livestream screen will stutter for about 0.5 seconds and then return to normal.-
